Third Party Site to site VPN
Sajid
Hi all,
I am trying to create Site to Site VPN where one site is having MX64W and another site is having Check Point R77.30 virtual instance.
When i go on dashboard Security appliance > Configure > Site-to-site VPN > Non-Meraki VPN Peers,
here Non-Meraki VPN Peer is not showing under Site-to-site VPN Tab.
Please suggest a solution.
did you select type: hub or spoke
Adam
@ww is correct.  Set your MX up as a Hub or Spoke then you should see the 'Non-Meraki VPN Peers' option at the bottom of the page under Security Appliance>Site-to-Site VPN
Doke
Btw good luck if you need to do some NATing on your side with that non Meraki peer, I hope you have better luck than I did.
