Tested carriers for LTE devices(MX)
Which Carriers or ISPs use the LTE devices(MX)?
I would like to know the list of Carreris or ISPs.
Thanks,
Accepted Solutions
Re: Tested carriers for LTE devices(MX)
@CKYI wrote:
Thanks,
Carriers do not use LTE MX/Z3 devices, nor do ISPs.
End users, and some managed services providers use MX/Z devices.
If you want to check if a MX with a built-in LTE module will operate correctly when connected to a network operated by a specific MNO, just ask. Across most of the world, customers and distributors will have to check for themselves.
You have asked about this previously, and received answers.
6 REPLIES 6
Hi @CKYI
I am not sure if the following documents helps you with the information your are looking for.
https://documentation.meraki.com/MX/Cellular/3G_-_4G_Cellular_Failover
https://documentation.meraki.com/MX/MX_Overviews_and_Specifications/MX67_and_MX68_Overview_and_Speci...
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
@CKYI wrote:
Thanks,
LTE in the US on MX67 or 68.
My recommendation is use T-Mobile if possible, then Verizon.
May we get the test items for the certification of Carriers or ISP/MSP ?
I'd like to check the test items for the preparation.
Ask the MNOs.
Verizon works
