Test client vpn from internal
ZDonaldson
All, with my previous firewall product I was able to test client vpn connections by connecting either from behind the firewall or using the guest wireless network.
This does not appear to be working on our new MX device.  Does anyone know how to allow this to happen?
Zane D - IT Manager in Sin City NV
3 REPLIES 3
MilesMeraki
To my knowledge, there is no way to test this feature from LAN of the MX. I'd recommend hot spoting your phone and testing?
I appreciate the advice on that...I can certainly do it, but I would consider that a workaround and a missing feature.
BeckerIT
One way you could test your client VPN is if you have access to a second internet connection.
