Swap out MX 250 Warm spare vs cold swap
hmc25000
I need to swap out our 250 MX because of an issue with the current one crashing.
Reading the documentation I'm inclined to assume that configuring a warm spare might be easier and have less downtime than doing a cold swap.
Can anyone with experience recommend what the best way is with the least amount of downtime.
2 REPLIES 2
MerakiDave
Hi @hmc25000 this also came up in another recent thread below.  Check here https://documentation.meraki.com/MX/Other_Topics/MX_Cold_Swap_Replacing_an_Existing_MX_with_a_Differ...
In particular look over the section "Adding a Second MX to Form a Warm Spare Configuration" which seems most relevant and is going to minimize your actual downtime if you've got a tight outage window.
Hope that helps.
Thanks.
I'm a little confused with method 1 from the document. If I understand it correctly the Method 1 can be done
"Adding the Replacement MX to the Same Network" or "Adding a Second MX to Form a Warm Spare Configuration".
I understand for both you have to remove the old MX prior to adding the new one. How can you add a warm spare if you have removed the old MX? Can I assume there will be no downtime when I add the new as a warm spare and than remove the old MX? I just want o make sure I understand it correctly.
