One of my customers has an MX84 running 14.53 stable. This AM a Cisco Small Business switch connected to one of the HPE switches that are the main access switches for their the LAN stopped passing traffic on the primary (untagged) VLAN. All devices attached directly to the HP switches were fine.
Figuring the issue was with the Small Business switch the service provider for the software solution that the SB switch was associated with had them reboot the switch. This made no difference.
I grabbed a clean 2960S and dragged that in to troubleshoot.
- Plugged it into one of the HP's, it wouldn't pass traffic on the primary VLAN.
- Plugged it directly into the MX84, it wouldn't pass traffic on the primary VLAN.
- Set the port I was plugged into as an access port for VLAN 2? Passed traffic no problem.
I ended up rebooting the MX84 and then everything just worked properly again. The entire time, anything plugged into the HP switches were fine and VLAN 2 was wholly unaffected. Quite odd!
