Hey guys
Bit of a weird one, thought it was going to be easy but I may have overlooked what can be possible.
So I have an organisation that has a sub-company (separate entity), both use Meraki MX64.
Company 1 has a connection into the internet and Company 2 is using a NAT'd IP from Company 1.
Company 1 needs to be able to connect the computer in Company 2, so I've applied a Static route on the 10.0.99.0/24 subnet to route through 192.168.0.30.
In the traceroute and packet trace, I can see that any ping going to 10.0.99.3 successfully routes to the company MX64 but then packet doesn't get delivered, as if the MX64 in Company 2 doesn't know where to route the ticket or the Meraki is filtering/dropping the packet.
On the packet capture of the Company 2 I can see the ping request, but there is no reply!
What should I look out for?
