Static NAT 1 VLAN to WAN IP other than Interface IP (Meraki MX)
KyleHB
I was wondering, is it possible to assign 1 Public IP to a specific vlan/subnet other than the interface IP?
eg. WAN Interface IP - 1.1.1.1
I would like my VLAN 99 to be statically assigned to 1.1.1.2 not the interface IP
All I can see is the 1:1 NAT which can only translate one host. Is it possible to do this on a whole VLAN?
jdsilva
Nope, this functionality is not available.
Also,be aware that 1:1 NAT is for INBOUND traffic only. Outbound traffic is always NAT'd to the IP of the MX.
jdsilva
KyleHB
Thanks for the response jdsilva.
Is there any work around on this issue? Because we availed a public IP block of /26 hoping that we can configure a per subnet=1 public IP.
jdsilva
Probably not one that you'll really like.
You could connect both WAN ports to your Internet service, and assign 1 IP to each WAN port. Then under SD-WAN and Traffic Shaping you can use Internet Flow preferences to route source VLANs out specific WAN interfaces and therefore being NAT'd to different IP's. The caveat here is that when either WAN port fails your traffic will fail to the other WAN port and be NAT'd to that IP. And of course, you can still only use the IP of the MX interface so you can leverage 2 public IP's at most.
I don't have any other tricks up my sleeve, but maybe others here do and will chime in.
KyleHB
Not possible in my case I think. Our MX only has 2 WAN interface and we have 2 ISP each with /26 public IP blocks.
Sucks to migrate to a cloud platform that lacks functionality. I hope 'Make a Wish' will help fix this issue in the future.
Thanks again for your help. Topic answered.
