Specific MAC rule for MX
Jonasy
The default rule of the MX series network is all-pass. We want to allow only a specific MAC to use the network in a certain VLAN, and the other unconfigured MACs cannot connect to the MX at all. Is there a recommended setting method?
Can I set the default route of 0.0.0.0 to a certain router of the LAN, and only use SDWAN for a specific network segment?
Thanks.
KarstenI
You can change the default rule to "deny any any" and apply a group-policy to the client with access where the network rules are overridden.
For SD-WAN, you can specify which networks are part of the AutoVPN. What do you want to achieve exactly?
2 Replies 2
KarstenI
Inderdeep
