Hi All
Looking for some advise here
At the moment i have 13 MX that have auto vpn configured, all of them are running Firmware 15.44 and there is only one VPN HUB in the network this HUB runs Firmware 14.53, with this setting the remote peers can connect an internal SAP app that we use at our remote locations, the problems begin at the moment i upgrade the VPN HUB to 15.44 then all of the remote vpn peers start failing to connect to a local server that is in the same network as the VPN Hub, when i upgrade i can ping the server wich is ip 192.168.2.13 so basic connectvitiy is there, i took packet capture before and after firmware migration of the HUB
In this example remote peer is 192.168.6.131 and the server to connect is 192.168.2.13
Im attaching a .rar where the capture is done in FW 15.44 and the peer cannot connect, and then i downgrade to 14.53 and take another capture where the same peer can connect to the server
this is a screenshot of the error i see when FW is 15.44
https://drive.google.com/file/d/1xHW4IxR7oCEI343N5UVVnrIAPYrFB8Nd/view?usp=sharing
