Specific IP allow for Internet
Rajinder
Dear All,
I have a network in which I have MX100 and core switches.
MX100 is connected to Internet on a fixed Public IP.
All the SVIs on Core switches
I have a default route towards MX100 and there is a VPN between MX and non meraki device from where all the subnets are getting the services.
I have one subnet 10.x.x.10/27 on Core switch and it has already a default rule towards MX100.
I want to allow only one IP for Internet rest everything should go locally/VPN.
How I can do this ?
Layer 3 firewall rules.
When is the destination prefix going over the VPN and I'll mock something up for you.
Rajinder
Dear Philip,
Didn't get it, Can you please define it in detail.
If you go:
Security Appliance/Site to Site VPN/Organization-wide settings/Non-Meraki VPN peers
What private subnets have you got listed?
AjitKumar
Hi Rajinder
Check if the following L3 rules helps you achieve your requirement under Security Appliance->Firewall.
Information:
1. Allow Meraki Firewall Subnets and Ports for the Core Switches to reach cloud. (Help->Firewall Info)
2. Allow the specific IP to reach "Any Destination"
3. Allow clients to reach VPN Subnet
4. Deny All Access
Regards,
Ajit
AjitsNW@gmail.com
www.ajit.network
