Site-to-site VPN to AWS
SteveDW
Is there a way to create a site-to-site VPN from a Meraki MX100/250 to AWS without purchasing a vMX? I've seen a few articles about configuring the MX SD-WAN site-to-site with third party routers such as SonicWall and Azure. Thanks in advance.
3 REPLIES 3
alemabrahao,
Thank you so very much for your quick response. I really appreciate it. Such wonderful help! Please enjoy your weekend!
GreenMan
Bear in mind that the non-Meraki VPN tunnels (i.e. Meraki at one end only), created this way are straightforward secure, point-to-point connections;   you don't get the same resilience and traffic engineering capabilities (SD-WAN, basically) that you get through deploying VMX in AWS and using AutoVPN (MX at both ends).
