Site-to-site VPN to AWS
SteveDW
Is there a way to create a site-to-site VPN from a Meraki MX100/250 to AWS without purchasing a vMX? I've seen a few articles about configuring the MX SD-WAN site-to-site with third party routers such as SonicWall and Azure. Thanks in advance.
Yes, look at this:
https://ritcsec.wordpress.com/2018/08/12/a-visual-guide-to-setting-up-a-meraki-to-aws-site-to-site-v...
Yes, look at this:
SteveDW
alemabrahao,
Thank you so very much for your quick response. I really appreciate it. Such wonderful help! Please enjoy your weekend!
GreenMan
Meraki Alumni (Retired)
Bear in mind that the non-Meraki VPN tunnels (i.e. Meraki at one end only), created this way are straightforward secure, point-to-point connections;   you don't get the same resilience and traffic engineering capabilities (SD-WAN, basically) that you get through deploying VMX in AWS and using AutoVPN (MX at both ends).
Shubh3738
Go with VMx, It make your network simpler and no- dependent, for any site location if you have- to DC.
Its look like SD WAN connectivity after the deployment of the VMx on AWS. (either same or different vpc).
