Site-to-Site VPN (Non Meraki Peer) using secondary uplink
CBMontesclaros
Hi Meraki Peeps.
Good day. Would like to know if we have a solution for this scenario.
Primary Uplink will use ISP 1.
Secondary uplink will use ISP 2 and will be used by Site-to-Site VPN (Non Meraki Peers which is AWS).
Is this possible to be configured on the MX device?
We had a same situation but we are also using ISP 2 as the primary uplink. However, when I shifted to ISP 1 as the primary uplink, we had issues on the S-to-S VPN connection. We want to avoid configuring anything on the non-Meraki peer side (AWS).
2 REPLIES 2
It uses the primary, ( wan1 or wan2 depending on which you set to primary.)
You can work with flow preferences  to send other traffic to other wan interface
https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/MX_Load_Balancing_and_Flow_Preferen...
You'll get a lot more flexibility if you use something like a VMX-S in AWS.
https://meraki.cisco.com/product/security-sd-wan/virtual-appliances/vmx-small/
