Does anyone know that if Meraki MX is behind NAT, is it possible to make VPN tunnel with Azure vpn-gw ? I am using beta firmware and activated ikev2 via support. Azure documentation says no. but is there any workaround ? portforwarding etc..
Tried ipsec passthrough mode and a dmz mode which was the most open option on tp link mr400 4g router. In all settings the router gives a private ip to mx. Azure does not like that.
Is your provider on the 4G router doing carrier-grade NAT? If so, I don't think there's any way you're going to get around that. AutoVPN to a vMX could cope, but you've said that's not an option.
