Simple question - newbie here
Sharyn
Hi.
I am just trying to verify that an MX84 hardware appliance on site will play nicely (work!) with the vmx100 in Azure to create a stable site to site vpn connection.
Although the documentation says "MX" in general,  it doesn't actually state that the mx84 can be successfully used with the vmx100.
Thanks in advance.
Sharyn
DarrenOC
Hi @Sharyn , the two will play nicely. Still Meraki technology albeit ones physical and the other virtual.
5 Replies 5
DarrenOC
Sharyn
Thank you. I figured they would, I just wanted to check with the experts.
DarrenOC
Welcome to the board and good luck with your deployment.
im sure you’ve read this already:
https://documentation.meraki.com/MX/Installation_Guides/vMX100_Setup_Guide_for_Microsoft_Azure
Sharyn
Thank you for the welcome.
Yes, I've read it several times.
We already have an MX64 and are in the process of upgrading which includes a site to site connection with Azure
You all will probably be seeing a lot of me 🙂
Thanks!
Sharyn
GreenMan
Meraki Alumni (Retired)
We'll be happy to help, but don't forget - your Meraki license buys you 365-day, 24 x 7 access to Meraki Support.   If your query is urgent, picking up a phone gets maximum priority over email / cases raised through Dashboard.  (check out Help > Get help, top right of Dashboard)
Remember to check out the Meraki documentation pages before asking - the aim is that the KB articles are 'Meraki-simple' to access and understand - plus you're likely to get pointed there, if that's where the answer is available, whomever you ask   😁
So, just by way of example:   https://documentation.meraki.com/zGeneral_Administration/Support/Contacting_Support
Enjoy your Meraki journey!
