Setting up Port forwarding for Rustdesk
penangit
Hi everyone has anyone setup a rustdesk server self hosted and did a port forwarding via meraki?
I got a MX 95 and I've self hosted rustdesk server, internally local lan it works no issue, did setup a port forwarding so I can remote to my work pc for minor tech support,
So basically
self host server
my home pc to work not working
my work pc to home working✔
work pc to other work pc working✔
other work pc to my home pc working✔
my home pc to other work pc not working
Been going through this with Meraki Customer Support and our ISP technical support they're pushing me towards each other basically,
From my home pc or laptop I can ping the public ip of my work,I can even see the devices on the same server online no matter what I can't connect, wanted to ask here if there's any other solution otherwise my last option is to get a cheap vps or something for this
https://rustdesk.com/docs/en/self-host/
Above is the link to rustdesk documentation
Meraki Customer Service has confirmed my port forwarding settings are correct based on the rustdesk documentation.
2 Replies 2
Port forwarding in Meraki is relatively simple.
Is Wan configured with a public or private IP?
https://documentation.meraki.com/MX/NAT_and_Port_Forwarding/Port_Forwarding_and_NAT_Rules_on_the_MX
IvanJukic
Meraki Employee All-Star
Hi @penangit ,
Try having a look at the Firewall Log monitoring tool.  If your MX firmware is 18.2 or newer. You can use this tool to display if the traffic is blocked. I would also suggest to check your Firewall rules as well. See guides below.
https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/Firewall_Logging
https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/MX_Firewall_Settings
Cheers,
Ivan Jukić,
Meraki APJC
If you found this post helpful, please give it kudos. If it solved your problem, click "accept as solution" so that others can benefit from it.
