- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
Setting up PPPoE on MX64, ADSL connection that uses Multiplex VPI and VCI values
I am replacing a Netgear router with a MX64. The ADSL connection setup on the router uses the Multiplex method and uses VPI and VCI values together with username and password of course, Is it even possible to configure the MX with VPI/VCI values for PPPoE adsl connection?
I know how to setup PPPoE on MX, the question is only regarding the VPI/VCI values for this certain connection.
Thank you.
Miyagi.
Solved! Go to solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
No. You would have to bridge the PPPoE frames to the Ethernet port of the DSL router.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Thanks for the quick response.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
You may disable NAT, if required.
It appears that Bridge mode is only applicable if (multicast) IPTV is accessed.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
What modem are you using?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
It is a Netgear D6400.
