I know there's an on-demand reboot option, but is there not functionality in place to schedule a reboot to occur at a certain time? i.e. it would be nice to schedule reboots in the middle of the night.
Thanks!
No there isn't. You can use the API. @NolanHerring wrote a script and he shared it here:
https://community.meraki.com/t5/Solutions-APIs/Python-Script-Rebooting-Devices/m-p/49576
All props to Nolan :)!
A little bit more forceful and used probably more for single sites
from meraki.meraki import Meraki # Configuration parameters and credentials x_cisco_meraki_api_key = 'your_api_key_here' client = Meraki(x_cisco_meraki_api_key) collect = {} network_id = 'L_networks_id_here' collect['network_id'] = network_id serial = 'mx_serial_here_with_dashes' collect['serial'] = serial result = client.devices.reboot_network_device(collect) print(result)
This should be a feature. Example: We changed DNS to Umbrella on the MX and now the switches have a yellow status. Should reboot them during the evening but needs manual attention.
Def agree, the whole Meraki Dashboard is all about ease of use and clean UI, seems like a no brainer.
Can't believe that 3 years later this still isn't a feature. Would be an immense help for us.
Let's get this going folks! Its time.
Agreed - They've integrated Anyconnect into several MX devices now with new firmware (THANK YOU DEV TEAM!) but haven't integrated this simple option?
We have an MG21E which we use on remote sites. Defeats the purpose as we need to on site to reboot the device.
A simple reboot function when it fails to ping default DNS should solve this issue. This is common feature on most remote routers.
We have a vMX that keeps losing connection to a VPN every 24-30 hours (don't ask!!), which is fixed with a reboot, so being able to schedule a reboot every night would be one less task to do every morning!!!
Hi All , Bit late to the party but just to let you know we have now created a new app for this function that you can download on IOS or Android . You can create groups of Meraki devices from any Network / ORG and schedule reboot times . You can also reboot groups of devices at any time you want . https://meraki-rebooted.com/ . Hope this helps 🙂
