We have dual WAN connections.
Primary = WAN1 (1Gb)
Failover = WAN2 (500Mb)
We are not using the load balancing option.
Just wondering if it's possible to create a policy or schedule to route our cloud backup server to use WAN2 during office hours, then switch back to WAN1.
I've been manually entering the static IP of our backup server to a flow preference rule and it works as expected, but it would be spectacular just to have this as an automated schedule.
Hey @ArtM. Sorry, no it's not possible to put a schedule on the Internet Flow Preferences.
Couldn't you tell it to load balance and set it to a limit of 1Gb so it won't saturate the primary link?
This would be a really great Make A Wish if you haven't done that yet. Meraki really does pay attention to those. I recently spoke to Research regarding a wish I had made.
That said, we typically solve this problem by establishing time windows within the backup software itself.
I didn't see anything in the API docs for flow preferences... Maybe I missed it?
I don't think it's in the API yet, unfortunately. That's why I think the best bet is throttling via the cloud backup program. Has the advantage of throttling the traffic close to point of origin, which is always desirable!
