All,
I've set up a port forwarding rule to allow TCP 22 to a particular server, in order to support an SFTP server.
The connection is successfully being made, user logs in, but file transfers disconnect after transferring only a few kb.
Error code in the sftp server is: Winsock error - 10054 which indicates the remote client is disconnecting.
Error code in the client indicates something similiar, the connection is being interrupted.
I've used several different clients and even at one point changed SFTP server software. I'm getting the same results.
As such, I've concluded it must be something related to my Meraki MX unit but I don't know where to find logs or what I would even check.
Any ideas would be appreciated
Zane D - IT Manager in Sin City NV
