We are moving to a new ISP, I have a /26 block that has been established but in order to use it I'm told that I must route it over a /30 they've provided in order to limit the size of the broadcast domain. We have over 40 externally facing instances and need to NAT about 30 of these IPs to internal web servers. Our current ISP gave us our existing IP block in the traditional way so that their gateway is part of the block so we have no need for a route. My question is do I need to setup a router between the new ISP and my MX400 or is there a way to make this all work within my firewall?
I've had Comcast deliver this way. It will just work and you can assign 1:1 NAT, etc. from you /26 as normal on your MX.
Where you could have a problem is if you plan to do warm spare and need more public IP addresses in a subnet on your WAN port.
"Kneel before Zod" lol!
That is all correct. I forgot to reply earlier that the ISR is perfectly good way to work around getting your /26 more properly usable if your ISP won't change. I have been battling and escalating with Comcast for nearly a month already on this same topic. They just won't change it. They will put in their own router (and charge) or we can do like you are planning..
