Mx on cellular port forwarding!
Antonionjeim
Hello everyone!
I have a meraki MX68CW that is running of cellular with no WAN at all.
How can I get around the limitation of port forwarding ?
BrechtSchamp
That may be something Meraki support can configure for you. Keep in mind that most providers disable incoming connections on cellular, so you might have to get in touch with them to see if it's supported.
Antonionjeim
Thanks for your reply,
i am located in Australia, and i know that our cellular providers are really restricted with things like that, i will give it a go anw.
Any other solution that i can do even if it require another hardware to be placed before the meraki?
thanks
Cmiller
You can get a static IP on most US carriers but that is pricey. Best to call your carrier, make sure they support incoming connections as @BrechtSchamp said. good luck
