Revisiting the MDNS conversation MACOS UUID
JED2021
Like everyone else there is a concern regarding Mac clients  and the UUID.
100% or our Macbooks only use wireless.
I noticed that Mac Minis and when my Macbook is connected to an MS switch via ethernet the  Proper name appears in the dashboard.
Has anyone else discoved this?
Any ideas  if it is a MACOS wifi client issue or a knob in my SSID that needs to be turned?
Thank you
8 Replies 8
rhbirkelund
This is most likely due to Apple (and Android for that matter) is using randomised MAC addresses, https://documentation.meraki.com/General_Administration/Cross-Platform_Content/Meraki_and_iOS_14_MAC...
The only way around this is to disable randomised mac addresses on the client itself.
Or, if the Macs are enrolled in Systems Manager, you could push the setting out with a WiFi profile.
The issue is on Macbooks (laptops) not Mobile devices.  The Mac address is not randomized.
Thank you
rhbirkelund
Are you sure? Afair, It's enabled by default on all Macbooks, and available to disable unless the device is MDM enrolled... I might be incorrect here, though..
can you clarify Afair?  and what is enabled by default
rhbirkelund
Afair = As far as I recall..
I think that Private MAC address/MAC address randomisation is enabled by default on Apple Macs, and cannot be disabled unless the device en MDM enrolled, and a profile is pushed to it, to disable Private MAC address.
I am searching for how to set this value outside of using the MDM.  Are you are of any CLI command line shell on MACOS?
JED2021
our MDM is KANDJI.  They say the issue is how MERAKI orders the device identification.
The Device on LAN identifies correctly. MACOS host name
The Device on WIFI identifies as the UUID.
I believe this occurred either with the latest MACO OS upgrades or Migrating to KANDJI from JAMF
Has anyone else seen this LAN vs WIFI MACOS device identification for clients?
JED2021
Kandji support states
One thing I did notice that may be a lead on why Meraki is reporting names/UUIDs improperly is that the first two computers you listed are running macOS 11 while the second set that you state show UUID on wifi are on macOS 12. I suggest following that thread with Meraki to see if there's some aspect there that is contributing to your scenario.
