I am relatively confident that MRs (that need 802.3at power) normally report they are getting 802.3at power from MX68 PoE ports. However I checked a few MRs this morning, and they are all reporting they are running in low power mode.
Does anyone have an 802.3at MR plugged into an MX68 PoE port not reporting low power mode? If so, what firmware version is your MX68 and your MR?
The last one I looked at:
MX68: 16.14
MR36: 27.7.1
You can see the PoE mode of the MR in the bottom left-hand corner of the MR dashboard screen.
