I'm a real newbie on Meraki product and network. Actually i just monitor and make some simple firewall rules.
I need to replace our MX60 firewall with a MX84. Apart the basic doc of the installation of the MX84 i found nothing to help me.
Is there some docs that show how do this replacement step by step (in simple english or better in french !) ?
Thanks !
Solved! Go to solution.
Remove the existing MX60 from the network, and then add the new MX84 to that same network.
Ok, thanks, but i need to reconfigure all settings or the settings are automatically affected to the new device ?
