Removing Fixed IP adress
LudwigD
Dear,
A long time ago I gave a Raspberry Pi a fixed IP adress.
This Pi is gone , but now I want to reuse this fixed IP adress for a new one. But trying to do this, how can I set this IP adress free again?
can't find this on the Dashboard...
Of course I can use a new IP adress (the easiest way), but... I want to know how to remove a fixed IP adress when the associated client isn't accessible (the smart way).
Thanks (again...)
LD
Accepted Solutions
Re: Removing Fixed IP adress
take a look at Reserved IP ranges or Fixed IP assignments at "Security Appliance/Teleworker Gateway > Configure > DHCP page"
https://documentation.meraki.com/MX/DHCP/DHCP_Services
2 REPLIES 2
LudwigD
Many thanks!
Stupid how I overlooked this.....
