Regarding a question
SD-WAN1
Connections are made like this
Internet 1 - Meraki router 1 - PC1
Internet 2- Meraki router 2- PC2
PC1 and PC2 are connected to same hub.
Now I need to know if I can ping from PC2 to PC1 and vice versa?
And communication from each PC to hub shouldn't disturb.
Is this infra possible on Meraki ?
If the subnet of both Spokes is enabled to participate in the VPN, they will know the route to each subnet through the Hub, and of course if you have any Firewall rules configured you need to release ICMP, otherwise it won't be a problem.
I didn't understand this sentence "And communication from each PC to hub shouldn't disturb."
You don't want communication to go through the Hub? Would it be this?
Another important point, often the Windows Firewall or aintvirus blocks ICMP, so if you are going to do a test, disable both.
You have to use the statefull vpn firewall.
https://documentation.meraki.com/MX/Site-to-site_VPN/Site-to-site_VPN_Firewall_Rule_Behavior
Other option is stateless fw rules using group policies . Attached to a vlan or client
Do you mean "Meraki Router 1" and "Meraki Router 2" are connected to the same hub?  If so, then if AutoVPN is enabled on the Meraki MX devices than the PCs will be able to talk to each other.
