Recommendations - Connecting MX to Cisco 4500 resilliently
Pugmiester
Hi all,
Our new MX250's have arrived onsite and I'm working through the physical connections ready for installation. I was planning to use an Etherchannel between the MX and the Cisco 4500 but I understand the MX's don't support Etherchannel/Bonding.
I don't need dual links for capacity, it's solely so we don't have a single point of failure in case one of the 4500 modules fails.
What would you recommend to provide a secondary connection with a quick a failover as possible?
Thanks,
Martin
2 Replies 2
Pugmiester
Thanks Philip, I'll take a look.
