Hello!
I have a question is this possible use 2 different radius servers for authorisation different users
Example
radius server 1 have user A
radius server 2 have user B
I want that user A when connected to VPN meraki use radius 1 server
user B when connected to VPN meraki use radius 2 server
Is this possible?
https://documentation.meraki.com/MR/MR_Splash_Page/RADIUS_Failover_and_Retry_Details
You can specify multiple RADIUS servers, and they will be challenged in sequence.
Can you be more specific in how the directories that your RADIUS servers are accessing are unique from each other?
Thanx for Article
It's for VPN client on meraki
I thought that when you add another Radius server if 1-st radius didn't know login user it's sent to another
It should do that, but can you give more clarity as to why you would construct a user directory in such a fashion?
It necessary because of we have users logins with different domains
This would probably be best solved IMO by pointing the Meraki at one of the RADIUS servers, and then having that server either process or forward (proxy) requests to the second server that match a given set of rules.
I don't believe this functionality is built natively into the Meraki platform.
