Quick way to block random IPs from list
NWNSM1
If I have a list of 200 IP addresses I want to deny thru the firewall, is there a quick way to add them?  (They are *NOT* a continuous range.)
2 Replies 2
BrandonS
I think you might need to take this opportunity to learn how to leverage the API. This looks spot on for what you want to do: https://developer.cisco.com/meraki/build/mx-firewall-control-python-script/
As for quick, it may be a wash comparing how long to copy paste them manually vs. getting a script setup, tested and working, but once you have this setup you should be able to make large batch changes quickly next time.
Best.
If they are comma seperated you can put them in 1 field.  Not sure what the limit is for 1 field
