Questions about VPN and NATs with 2x MX75 in HA pair
mvalpreda
I know how to set up the virtual IP address on the WAN side for 2x MX devices in HA - 1 public IP per device and another IP address for the virtual IP.
If I am using AnyConnect, where should the clients connect? The DNS name that comes up for the virtual IP address in the dashboard?
Should there be [near] zero downtime with anything on the one-to-one or one-to-many NAT rules if there is a failover event?
10 Replies 10
The address that must be considered is that of the VIP. As for the time of the failover event, it is transparent to the user, it should lose a maximum of 2 or 3 pings.
Correct.  Otherwise the automatic certificate name won't match.
No state is synced between the two MX.  When a failover happens, all connections are dropped and must be made again.  In the case of AnyConnect, users need to reconnect.
@PhilipDAth  I've already done several failover tests and I didn't have any problems, it was practically transparent, at most 2 or 3 pings were lost.
Try a long-running TCP connection, like a download.  You'll see that it fails.
But I agree, it is not noticeable for most things.  Userw mostly use their web browser these days and expect to just click reload.
mvalpreda
Failover tests on the VPN? Or something else?
Tests on local LAN and S2S VPN. Client VPN is necessary to reconnect as mentioned by @PhilipDAth .
mvalpreda
Thanks for that info.
One firewall rules for other one-to-one NATs, is that using a virtual MAC address between the two devices?
For instance, I have WAN for MX1, WAN for MX2, and then the VIP for that. I have other NAT rules for the rest of the /29 block - one of those being SIP.
Am I going to have a problem with upstream ARP cache? Or does it use a virtual MAC address like I read about?
geektoyz
Sorry for post to old chat.  Do the MX75 appliances support HA pair?  Seems we had a sales call last year sometime where we were told MX85 or higher was needed for HA pair.  I don't see info here:
https://documentation.meraki.com/MX/MX_Overviews_and_Specifications/MX75_Datasheet
or here
https://documentation.meraki.com/MX/Deployment_Guides/MX_Warm_Spare_-_High_Availability_Pair
They support HA.
geektoyz
Awesome!  thanks Phil.
