I'm attempting to setup a warm spare configuration for our MX devices using design seen above (With just the 1 ISP) but I'm trying to confirm a bit of information I'm unclear on. When it mentions creating VLAN 700 for the ISP connections there is no mention on what IP addresses should be assigned to the VLAN. Should I just pick a random private subnet and just statically assign the public IP addresses to the MX WAN ports or should I create the range that's the same as the public IPs that the ISP has given us. I'm statically assigning the IPs on the MX either way but wasn't sure if the subnet/MX IP that I choose for this ISP VLAN matters.
Ah! Thanks a lot! I didn't realize I could simply assign the switchports to the VLAN from the switch dashboard itself without the VLAN already existing under "Addressing & VLAN". I deleted the created VLAN and left the ports with the VLAN assignment.
Thanks!
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_7c3406a608b5d","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_7c3406a608b5d_0","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_7c3406a608b5d_1","feedbackSelector":".InfoMessage"});
LITHIUM.InformationBox({"updateFeedbackEvent":"LITHIUM:updateAjaxFeedback","componentSelector":"#informationbox_7c3406a608b5d_2","feedbackSelector":".InfoMessage"});
LITHIUM.AutoComplete({"options":{"autosuggestionAvailableInstructionText":"Auto-suggestions available. Use Up and Down arrow keys to navigate.","triggerTextLength":4,"autocompleteInstructionsSelector":"#autocompleteInstructionsText_7c34063b15754","updateInputOnSelect":true,"loadingText":"Searching...","emptyText":"No Matches","successText":"Results:","defaultText":"Enter a search word","autosuggestionUnavailableInstructionText":"No suggestions available","disabled":false,"footerContent":[{"scripts":"\n\n;(function($){LITHIUM.Link=function(params){var $doc=$(document);function handler(event){var $link=$(this);var token=$link.data('lia-action-token');if($link.data('lia-ajax')!==true&&token!==undefined){if(event.isPropagationStopped()===false&&event.isImmediatePropagationStopped()===false&&event.isDefaultPrevented()===false){event.stop();var $form=$('
