QOS
RahulPrasadh
QOS
How to enable QOS for prioritize voice packets on Meraki.
pmhaske
Hello @RahulPrasadh,
QOS rules can be configured under Security appliance > Configure > Traffic shaping. Please see the KB article below to create traffic-shaping rules. Also, linking VoIP FAQ KB in case you are interested in additional information for VoIP on Meraki devices.
https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/SD-WAN_and_Traffic_Shaping#Creating...
https://documentation.meraki.com/General_Administration/Tools_and_Troubleshooting/VoIP_on_Cisco_Mera...
6 Replies 6
GIdenJoe
If you're talking about outbound QoS on the MX appliance towards another location or the internet then you need to set this on the Security & SD-WAN -> traffic shaping page.
Then you need to add a rule where you match on your voice application or a L3/4 match criterium and set the DSCP value to 46 - EF.  This will effectively put voice traffic on the realtime queue.
RahulPrasadh
For example, in Security & SD-WAN -> traffic shaping. Add a new shaping rule Definition (All VoIP & Video conferencing, Bandwidth limit (Obey network per client limit), Priority (High), DSCP tagging (46 EF) will this configuration work?
GIdenJoe
That will work for both voice and video if NBAR can detect the application.
However you want only voice to have the EF treatment.  So inside that category group you should only add the voice version of the application and give it EF.
Then have a second rule below it matching all voip and video conferencing and give that AF41 with high bandwidth queue.
pmhaske
RahulPrasadh
Hi @pmhaske ,
pmhaske
Hi @RahulPrasadh,
Yes, that should do it. You can also add custom expressions for a more specific set of IPs or subnets.
