I am trying to use a MX64 as the 'core' router on my lab network. I have 2 VLANS which are all /24s that follow the addressing 10.1.1.0/24 for vlan 1, 10.2.2.0 for vlan 2. for this example
I would expect to have to set up routing between 10.1.1.1 and 10.2.2.1, however the MX allows routing between vlans by default. This in itself is not a problem, and I attribute it to the default layer3 firewall rule to allow any any. Therefore, I created a policy to prevent routing from 10.1.1.0/24 from routing anything in the 10.0.0.0/8 private address space. This did not work, so I suspected that this may be in logical conflict because 10.1.1.0/24 itself is within the subnet mask of the rule, however when i changed the rule to prevent 10.1.1.0/24 from routing to 10.2.2.0/24 specifically I can still ping from any 10.1.1.0/24 machine to the gateway 10.2.2.1
My rule is as follows
policy = deny
proto = tcp
source = 10.1.1.0/24
src prt = any
destination = 10.2.2.0/24
dst prt = any
comment = no inter vlan
Can someone help me understand what i'm doing wrong?
