Post VLAN configuration
IrfanKhan31
I am new to Cisco Meraki firewall.
I am deploying a new network and in order to do that, I have created a new VLAN, what I am trying to achieve is to, assign that IP to a new resources that are coming to the network like Brand New Dell Servers.
I have created a VLAN for Server, what will be my next step. Please assist.
I don't know if I understand very well what you want, are you talking about DHCP?
Meraki is like any other network equipment, in fact even simpler and the logic is the same.
If it's about DHCP you can check these documents.
You can also find topology examples in the documentation.
https://documentation.meraki.com/MX/DHCP/Configuring_DHCP_Relay
https://documentation.meraki.com/MX/DHCP/DHCP_Services
7 Replies 7
IrfanKhan31
What I am trying to understand is that after adding VLAN what are my step by step setup to complete VLAN. So that I can assign IP to the New Servers from that newly created VLAN.
Configuring a port and connecting the server to the MX would be a good start.
https://documentation.meraki.com/MX/Networks_and_Routing/Configuring_VLANs_on_the_MX_Security_Applia...
https://youtu.be/8_XqqT0d0Go?si=_7bCabMMISpzh5Qx
IrfanKhan31
Just so more I can understand, do I have to do any sort of configuring on the physical Cisco Meraki ethernet port for the VLAN.
CptnCrnch
Everything you're asking for is described here: https://documentation.meraki.com/MX/Networks_and_Routing/Configuring_VLANs_on_the_MX_Security_Applia...
Anhing else that's unclear?
IrfanKhan31
Not as of now.
Thank you for all the help provided.
