2 MX units & 1 MS Network?
Quimax
We have a single campus with multiple VLANs all terminating on a single MS425 switch. The MS & MX networks are separate networks in the Dashboard. Almost exactly as it's done in the documentation example: Layer 3 Switch Example - Cisco Meraki Documentation
Now, however, we're looking to add ISP 3 & 4 (yes, 4 different ISPs!). However, I cannot seem to figure how to route individual VLANs to a different Next Hop IP.  The MS is 172.23.111.2, MX1 is 172.23.111.1 and the nex MX is 172.23.111.3
How can one tell the MS that 172.23.68.0/23 should route through 172.23.111.3 while 172.23.72.0/23 routes through 172.23.111.1 ?
1 Reply 1
You cant.
The ms does not have source/policy based routing.
Maybe you could move some layer3 vlans to one mx, and trunk them on layer2 to the switch
