Port # a device is connected to on the MX
lpopejoy
I noticed yesterday that you can view the actual port # that a device is connect to on an MX when you are using the mobile app. This was surprising to me - as I have always wanted this info.
Any plans to make this available in the web UI?
5 REPLIES 5
Brash
You can see this for clients in the dashboard if you hit the spanner button on the right hand side and add the "port" column.
lpopejoy
Unless I’m mistaken, I don’t think that shows unless you have a Meraki Switch. At least it doesn’t show for me. You are talking about network wide->clients, right?
You are right. You can only select port in the client view  if you have a switch. And then you can also see it for the mx.
Dont know if its a bug or expected
Brash
You're right - the ports I was seeing was devices connected to a switch.
Weird that it would be different between website and app.
This is the information that was in the dashboard for a day or so and to me has the same issue, so I am surprised that it is still there.  On an MX75 that I have in routed mode with most ports set to access VLAN x, I have:
Device Name
Port 6 via (MX name)
On the details tab I have:
Wired connection
Security gateway (MX name)
Port                      5
This mismatch is exactly why the web page was pulled and it appears to have not been fixed in the app...
