Port Forwarding on isp router to allow VPN client working on MX
Tedd
Hi Team,
I have a router Isp that we called Busness boost.Its not a fix public ip . The Router port ip address is 192.168.100.1 and on the MX its 192.168.100.18.
Do i need to do a port forward on the router to allow the VPN client to a access a server on the LAN.
I asume client vpn is not working now?
In case of a nat router
You need to forward ports(udp 500 and 4500) on the nat router to 192.168.100.18
https://documentation.meraki.com/MX/Client_VPN/Guided_Client_VPN_Troubleshooting#No_Users_Can_Connec...:
Tedd
Thanks. I will try it tomorrow on the Business Boost Router and Keep you in touch Sir.
Inderdeep
@Tedd : Apart from what all said here, Check this document as well
https://documentation.meraki.com/MX/NAT_and_Port_Forwarding/Port_Forwarding_and_NAT_Rules_on_the_MX
www.thenetworkdna.com
CptnCrnch
Most likely: yes
