Options for connecting MX450 to AWS Direct Connect... ( no BGP summarisation )
mrpackethead
Help me please!
I have an Mx450,  with one side connected to AWS direct Connect.   The SDWAN has > 100 sites, and if i advertise more than 100 routes to Direct Connect it will break.
As far as I can tell, theres no way to summarise the routes..
Looks like i'm going to have to stick another device in between just to do the summarization.. Very average..   Was looking for a meraki router with BGP features on it.. But that does'nt even exisit.
Are these meraki's serious or toys?
1 Reply 1
18.2 firmware has a bug :
Known issues
(Due to an MX 18.2 regression, MX appliances summarize AutoVPN routes advertised through BGP without being configured to do so.)
So mx seems to be able to do some things regarding summarization..
Maybe you can contact support and ask if they are able to help you.
