Non Meraki Peer Site to Site VPN : Data & Stats
Hi.
I am new to the Meraki Community having just installed a Meraki MX64 Security Device. I am experiencing problems with the single site to site VPN that I set up involving a non-meraki device at the other end. I am getting continuous reports in the Events Log suggesting that the ipsec process is failing at phase 1 (see below screen shot)
Oct 3 18:23:02 Non-Meraki / Client VPN negotiationmsg: phase1 negotiation failed.
Oct 3 18:23:02 Non-Meraki / Client VPN negotiationmsg: failed to pre-process ph1 packet (side: 1, status 1).
Oct 3 18:23:02 Non-Meraki / Client VPN negotiationmsg: failed to get valid proposal.
Oct 3 18:23:02 Non-Meraki / Client VPN negotiationmsg: no suitable proposal found.
Oct 3 18:22:20 Non-Meraki / Client VPN negotiationmsg: phase1 negotiation failed.
Oct 3 18:22:20 Non-Meraki / Client VPN negotiationmsg: failed to pre-process ph1 packet (side: 1, status 1).
Oct 3 18:22:20 Non-Meraki / Client VPN negotiationmsg: failed to get valid proposal.
Oct 3 18:22:20 Non-Meraki / Client VPN negotiationmsg: no suitable proposal found.
Oct 3 18:21:57 Non-Meraki / Client VPN negotiationmsg: phase1 negotiation failed.
Oct 3 18:21:57 Non-Meraki / Client VPN negotiationmsg: failed to pre-process ph1 packet (side: 1, status 1).
Oct 3 18:21:57 Non-Meraki / Client VPN negotiationmsg: failed to get valid proposal.
Oct 3 18:21:57 Non-Meraki / Client VPN negotiationmsg: no suitable proposal found.
Oct 3 18:21:44 Non-Meraki / Client VPN negotiationmsg: phase1 negotiation failed.
Oct 3 18:21:44 Non-Meraki / Client VPN negotiationmsg: failed to pre-process ph1 packet (side: 1, status 1).
Despite these logs the VPN is successfully passing traffic in both directions.
Another issue is the VPN status does not display any data such as throughput or connectivity. I read an article that described available stats but I could not ascertain if they are only available with auto VPN ie Meraki to Meraki links.
Any help or advice would be greatly appreciated.
2 REPLIES 2
Re: Non Meraki Peer Site to Site VPN : Data & Stats
It suggests there is a mis-match in the crypto parameters for the re-negotiation to keep happening.  Check that the subnets match up exactly on both sides.
Hi Philip. It turned out to be a mis-match  on Phase 1 lifetime settings. The MX end was set at 3600 seconds and the distant end was set at 28800 seconds.
Now that this problem has been resolved I am still at a loss on 2 points.
1. I get very little info from the VPN monitor facility, only a green dot depicting a healthy VPN. There are no stats or other info. Does that info only come with Meraki Auto VPNs ie a Meraki device at both ends. I have glanced at some lierature that refers to VPN registers but again I think this involves Meraki - Meraki VPNs.
2. Having set up a client VPN link for working from home I am trying to get access to the site to site VPN.
I initially set up a firewall rule to allow the VPN subnet access to the main subnet. That allowed my PC at home access to every resource within our main office. When I tried adding the subnet at the distant end of the site to site VPN I fail to get access to the resources at the VPN distant end
First setting VPN subnet 192.168.101.0/24 ------------- Main Subnet 192.168.100.0/24  OK
Second Setting 192.168.101.0/24 ------------ 192.168.100.0/24, 172.16.0.0/12 (added distant subnet) : Can still see main subnet but no access to distant subnet.
Any advice ?
