Non Meraki Peer Recommendation
endrianusgohan
I'm looking for non meraki peer recommendation which can connect fluently through IPSEC site to site. Are there any recommendations ?
I've tried Cisco RV, Grandstream, Sophos, Sangfor, but had problem with the connection. Most of them got hang up and had local problem connectivity.
Thanks a lot.
Inderdeep
Check with Cisco ASA or Fortinet. It’s working
Cisco Awarded Blogs 2020/2021 https://www.thenetworkdna.com/
10 Replies 10
Inderdeep
KarstenI
I have a couple of VPNs running between MX and Cisco ASA. Works like a charm.
Inderdeep
CptnCrnch
ASA is my typical go-to platform when it comes to S2S VPN because it handles almost everything flawlessly.
endrianusgohan
Hi @Inderdeep ,
Have you tried the fortigate branch especially branch 40F ?
Or what model have you tried from fortinet products ?
Inderdeep
endrianusgohan
is there any other vendor that do not require licenses to operate ?
Inderdeep
@endrianusgohan : I dont think any vendor without the licensing model may be @RestaurantGuy is telling when the license expires and you will get the grace period but that is always a risk. I would not recommend that approach.
RestaurantGuy
I've ran a Watchguard XTM-26 to an MX device for several years.  The XTM is now likely a model T15.  Several tech notes out there on how to set it up.
The WG devices come with a license when purchased but the device does not shut down when it expires, so you can keep using it.  Makes a decent VPN endpoint, although I'd likely go Z3 with a long license assuming this is for a small office, partner company or individual.
Cisco ISR1111-8P
Strongswan on Ubuntu,
