New S2S VPN between my Meraki Firewall and Azure
charlesfors
Hello:
We are planning to do the setup of a new S2S VPN between our end (firewall MX84) and Azure
First I would like to explain to you the configuration that we want to implement on our end
1-Our firewall has two lines connected to the internet.
2-Currently, the principal line (Verizon) is UP and it is using a "Site to Site" VPN between our end and Azure cloud that allows the connection between our private network and Azure
3-Now we want to activate the Comcast line as a failover line, so in case the Verizon line goes down, Comcast line goes UP automatically and keep the "Site to Site" VPN connection working without interruption
My question is:
1-Do I have to configure BGP protocol (in our firewall and Azure end) to achieve the failover?
Thank you, Charles
5 Replies 5
Maybe it will help you.
https://community.meraki.com/t5/Security-SD-WAN/Meraki-MX-250-HA-pair-and-Azure-VPN-Gateways-IPSEC-f...
Is the vMX on Azure one option?
I think it's more simple.
Using Azure, you might as well say the answer is no, because what you have to do to make it work is beyond most people.
If you value failover, buy a VMX-S.
https://meraki.cisco.com/product/security-sd-wan/virtual-appliances/vmx-small/
GreenMan
Meraki Alumni (Retired)
What @PhilipDAth said...    you likely will not get this working how you would desire using non-Meraki VPN.   If you purchase VMX (particularly if you purchase two, for resilience) it will be miles simpler, more resilient and provide you policy and performance routing too.
https://documentation.meraki.com/MX/MX_Installation_Guides/vMX_Setup_Guide_for_Microsoft_Azure
https://documentation.meraki.com/MX/Deployment_Guides/vMX_and_Azure_Route_Server
https://documentation.meraki.com/MX/Networks_and_Routing/Border_Gateway_Protocol_(BGP)
https://documentation.meraki.com/MX/Firewall_and_Traffic_Shaping/SD-WAN_and_Traffic_Shaping
JamesT91
Configure your Azure connection to the Dynamic DNS hostname of the MX, this will auto-failover, albeit rather slowly.
The real, elegant solution is to deploy a vMX in Azure.
