MX S2S VPN with Azure VPNGW
Naray
hi
I have three sites with MX installed. each MX has internet + 4g. each site needs connectivity with Azure. I am looking into vMX and VPN GW S2S vpn options. with vMX, connectivity/configuration will be very simple and AutoVPN will take care of VPN and failover (internet to 4G and vice-versa). i want to find out is it possible to create fqdn based s2s vpn between all 3 sites and Azure so that failover is automatic?
is there any blog or post which discuss integration between Azure and Meraki using local id and remote id?
The auto VPN is automatically, you don't need to configure any FQDN.
https://documentation.meraki.com/MX/Site-to-site_VPN/Meraki_Auto_VPN_-_Configuration_and_Troubleshoo...
https://documentation.meraki.com/MX/MX_Installation_Guides/vMX_Setup_Guide_for_Microsoft_Azure
This part is not possible.  Azure VPN gateway only supports static IP addresses for VPN peers.
Naray
JamesT91
Azure does support FQDN, sometimes it will error when you try to create in the GUI about it being an invalid FQDN, this is a GUI bug and if you create via Azure CLI it will work.
