I attempted to deploy an MX64 earlier today and failed miserably, clients were issued an IP address as expected, however no traffic ever hit the internet.
Is there a trick to get the PAT/hide NAT working correctly?
The MX could ping Google etc fine and I'm managing the device visa the cloud dashboard with no issues..
Firewall rules were all left to default, so I can't see those being an issue.
Basically there's so little to configure on the device I don't know what I can do to try to resolve, a typical ASA etc would be easier for me personally to fix!
Any tips or pointers much appreciated
Cheers
Rich
It kind of sounds like this wasn't a brand new device, is that the case?
In the dashboard possibly check the change log, to see if someone made some changes that could affect connectivity
The devices that were issued IPs can you ping them from the MX Tools?
The devices that were issues IPs can they ping 8.8.8.8?
Hi Rich,
Meraki MXes (Security Appliances) by default NAT the traffic. We need not do any special configuration for this.
MX can ping google. How about clients? How about traceroute on clients?
If the internet is working.
and
the MX is not blocking?
the PCs native firewall is not blocking?
any other 3rd party product is not blocking?
Clients shall reach internet. [You may try plugging PC directly on MX if already not]
Also as @SoCalRacer suggested kindly recheck the DNS Server settings and reach ability on clients.
Network-wide > Event log could be a place to monitor the logs on the Meraki Dashboard.
Are you plugging directly into the MX, or something else (like a switch) and then the MX?
If something else, are you using VLANs on the MX? Have you got a matching VLAN config on the switch?
Can clients ping the MX default gateway?
Can clients ping the Internet by IP address (such as ping 8.8.8.8)?
Tried both ways, either with a trunk port to a switch, or with one of the ports configured for access. In both instances devices are issued an IP and connectivity to the MX is fine, the issue is getting beyond the MX.
See above, if there were mismatching VLANS, clients wouldn't be able to ping the MX.
Yes
Nope
I know this is old, but did you ever resolve this?
I'm experiencing the same issue right now and Meraki tech can't seem to figure it out.
Yea was there a resolution to this? I'm dealing with the issue now as well at a customer site. I factory reset it and re-added the static IPs and still nothing--online but can't reach 8.8.8.8.
If your MX can reach the cloud then you should be able to do packet captures on your MX. So you could start a ping to some online IP and capture from LAN side of MX. Then capture again from Internet side of MX and see what happens.
