We recently connected WAN2 to our MX250. I have it doing load balancing.
In Appliance Status there is a network usage graph and wanted to confirm that it showing the throughput for each WAN and not the total throughput. I know it's balancing so they should be showing the same.
So in my case peak with be 450 Mbps per WAN and not 450Mbps in total across both WAN's
![Capture.PNG Capture.PNG](https://community.meraki.com/t5/image/serverpage/image-id/15392i74CD2C8EAA487EF9/image-dimensions/572x173?v=v2)
Thank you
