Need MX85 with WAN1, WAN2 and WAN3
Dan91
I have an MX85 currently setup with ports as follows...
Current setup:
Under WAN - GbE - WAN3 is primary Internet, WAN4 is the failover using the Meraki MG21E-NA (Cellular Gateway).
Desired setup:
Under WAN - GbE - WAN3 as primary Internet, WAN4 - secondary - failover to Starlink, set up LAN port 5 as WAN5 (Tertiary) failover to the MG21E-NA Cellular Gateway.
The question is, is this possible?
Thanks for any answers to this question!
Dan
Picture below shows WAN3 and WAN4 as the current setup.  LAN port 7 is the downlink to our LAN switch.
RWelch
You would need to use SFP modules (fiber or copper) are required for physical ports 1 & 2 and port 3 would then not be available for use.  Port 4 would be your tertiary WAN.
6 Replies 6
RWelch
On the MX85, MX95 & MX105 - The Fourth physical port is the designated backup port. Physical ports 1 & 2 become designated WAN 1 and WAN 2 ports.
- the Third physical port is disabled and unusable once MultiWAN is enabled
MultiWAN Backup Uplink
Mloraditch
This article describes the only way you can have 3 ISPs setup: https://documentation.meraki.com/MX/MultiWAN_Backup_Uplink
You can have 3 ISPs, but you would need SFPs for Ports 1 and 2, and Port 4 would be the tertiary.
Dan91
So, we are unable to convert a LAN port to be a WAN port.  Is that correct?
RWelch
RWelch
You can not convert a LAN port to a WAN port (no).
Dan91
Thank you.
