NPS and CA Static port issue
Kave
I have  a CA and NPS server in same VLAN and Same subnet, I can ping them but unfortunately When i set Static Port for CA i got RPC error, Port 135 is listening and ok but static port 10000 that i set it for CA can not start listening, i set it Allow  in In and Out band firewall as well, I do not know what is going on there. I have a MX withx2 VLAN one of them is management VLAN 1 and the another is set for 172.16x.x/24 subnet, The MX is connected to the nexus Via MX LAN portand nexus act as L2 and all VM is connected to the nexus.
kav noroozi
5 Replies 5
This seems to be a server issue.
Check if the server's firewall is blocking anything.
Brash
From what you've described, it definitely sounds like a server side firewall or port binding issue.
Kave
I dont think so, I wrote a firewall role for that port
kav noroozi
Have you tested the port locally on the server? A simple test is to isolate a host and the server from the firewall.
But honestly, I still believe it's a server issue.
By CA, do you mean Certificate Authority?
Are you saying you have changed the IIS port to 10,000 for web-delivered certificates?
What are you expecting to talk to the CA server?
What is reporting the error?
