NBAR blocking traffic to Umbrella DNS
jrsilvius
I'm having more issues with 16.16 on my MX65.
We have a layer 3 rule to allow UDP traffic on port 53 to any.
My MX is blocking my Umbrella devices from talking to 208.67.220.220 and 208.67.222.222 reporting them as Xbox Live.
Short of allowing all gaming, which I will not do, how do I fix this?
Any thoughts. The NBAR crap that Meraki introduced in 16.x is causing nothing but headaches for me.
You are going to need to open a support case to get this classification fixed.
6 REPLIES 6
16.16.4 had nbar improvements.
Are you using 16.16.4 or .5?
16.16, I haven't tried any of the additional patches as they didn't help my other NBAR issues in my other locations.
Bindhiran
Can you try adding those IPs to the white listing of the content filter?
I haven't tried that, but I'll give it a go. It didn't seem to help with the other NBAR issue I was having, so not sure if it will for this either. Also, the Allow List states that it is for specific URLs, so don't know if it will allow IPs.
They told me I needed to deny all the Layer 7 "gaming" category devices individually except for Xbox Live. That doesn't sound like a very good solution to me.
