My Meraki order number ????
Yeti2026
I have been locked out of my Meraki MX105 which was purchased with an internet upgrade through Lumen.
I received a notification on my Meraki that said to disable 2FA as they were discontinuing it. I did not disable it in time so now I am locked out. Meraki tech on a support case gave me a list of stuff I needed to get back in. I supplied him with all of that. The only thing left was he said I needed the internal Meraki order number. None of the order numbers I supplied them worked. Meraki support said those are Lumens numbers. I asked Lumen about it and they can not find this internal order number the Meraki tech keeps saying I need. I am stuck any ideas on how to find this would be greatly appreciated.
Thanks.
5 Replies 5
BlakeRichardson
To be honest I think you are between a rock and a hard place, I doubt there is much a community member can do to help although there might be a Meraki employee floating around that might be able to help.
DorianMess
Just browsing
@BlakeRichardson wrote:
Yeah… I kind of feel the same way. It really does seem like one of those rock-and-a-hard-place situations. I wish there was more we could do from the community side, but this might be one of those times where it needs someone from Meraki to step in. the best games and money here for example, https://golden-crown.casinologin.mobi/
Hopefully a Meraki employee spots the thread and can give you something concrete to work with. In the meantime, at least you’ve put it out there — sometimes that’s half the battle.
Doesn't it offer an option to use email MFA?
Tell Lumen you need the Cisco order number.  For me, they are usually a 9-digit number.  Lumen needs to contact the internal department that places orders with Cisco to get this number.
Also, when the order ships, an email is sent from notificationsapp_prd@cisco.com (have Lumen ordering look for this).  Sometimes customers get these as well.  This is an example of what I receive.
Yeti2026
Thank you. I got an escalation team assigned to this by emailing the CEO of Lumen. 😃
I was sent the order number I needed. Giving it to Meraki now to see what happens next.
MilesMeraki
Unfortunately this is one of the biggest issues with Meraki. Order numbers are normally tied to a partner etc.
If you're using Meraki or a customer using Meraki from a previous partner (Who purchased the kit) you're in this predicament.
Rule 1 - Always configure 2 admins per org for worst case issues like this.
That being said, I don't know how they can't help you if you have a org admin configured in the same org that is using your email address (Meraki can just email you from it to confirm).
Surely you can take a picture of the Meraki hardware and it has it's serial/MAC and send it to them via the email address you have as an Org admin in the respective meraki org?
