Mx not saving public ip configuration
kiruu15
When I try to configure a static public IP on a new MX. I enter the values, but it doesn’t save. It just reverts back to DHCP
8 Replies 8
Double check if you set the correct ip settings. Maybe try connect the router to a laptop with the ip settings to confirm that works
"If the MX is not able to reach the default gateway on this static assignment, it will fall back to DHCP"
https://documentation.meraki.com/MX/Other_Topics/Static_IP_Assignment#Local_IP_Assignment
kiruu15
i've already tried this many times, including resetting the device and changing the browser.
If you set the same static settings on a PC connected to the internet link, does it work and can it reach the Meraki cloud?
kiruu15
yes
Edu_Chico
Have you tried a factory reset?
Are you talking about a WAN interface configuration?
When you specify a static configuration on an already working MX, the MX will try it out, and if it loses Internet access then it reverts the change.
You could try configuring the static IP via the local status page.  That should stay on a static configuration then.
kiruu15
Yes about the wan configuration...did a static configuration using a local status page not saving
Alex413
I have had some issues like this on projects. what I would recommended:
unplug all cables from the MX.
do a hard reset - hold reset button for a good 10-15 seconds
connect to the MX local status page and configure WAN IP details (confirm they are correct)
reboot the MX and locally connect and confirm the WAN details are still 'saved'
then try connect again
